DIY: Remote controlled power windows!
    PREREQUISITES:
    -Alarm/starter with TWO aux outputs
    -Well-lubricated windows
    -2xAUX wires, and 12V Const wire run into the door
    -Aux functions must be 5-second-latch (sliding door mode). Latch-while-hold will also work.
    Pinout:
    1-BLU/GRN Motor Side
    2-BLU/YEL Motor Side
    3-RED/YEL Motor Side
    4-RED/BLU Motor Side
    5-IGN (12V when engine running)
    6-BLU/GRN Switch Side
    7-BLU/YEL Switch Side
    8-RED/YEL Switch Side
    9-RED/BLU Switch Side
    10-Polarity Select (see below)
    11-AUX 1 Input
    12-AUX 2 Input
    13-Chassis Ground
    14-12V Constant (15A Fused)
    STEP ONE: Get the parts
    You need SIX SPDT Relays. I used the 5-pin PCB model because they are small enough to fit in the door, and powerful enough (7 amps minimum). You also need some wire and a 15A fuse. And wire cutters, solder, and a soldering iron or butane lighter.
    STEP TWO: ASSEMBLE!
    Time to go Ikea all up in here. Make life easier for yourself and arrange the relays like in the diagram. They all face pins-up and in the same direction. Superglue them together, and start your soldering iron. Solder them up just like the diagram states.
    STEP THREE: Cut!
    Open your door and locate the following wires leading to the window control unit. Cut them, leaving room to attach wires to both ends of the cuts. Be sure to note the switch-side and motor-side of each wire when you cut it. This is very important.
    Red/Blue, Red/Yellow, Blue/Yellow, Blue/Green
    STEP FOUR: Attach!
    Solder it all up as best you can, taking care not to fuck shit up. Be sure to double-wrap your solder joints to best prevent shorts.
    POLARITY: Important!
    For negative AUX outputs, attach this wire to 12V Constant
    For positive AUX outputs, attach this wire to Chassis Ground
    HOW IT WORKS:
    This relay module controls just the FRONT windows.
    The bottom two relays flip-flop the polarity to control up/down motion.
    The upper four relays prevent the remote circuit from interfering with the switches. When the engine is running, window control is given to the switches in the door. When the engine is off, control is given to the remote unit.
    MODIFICATIONS:
    The vehicle has built-in relays to keep the windows activated until the door opens rather than when the engine is switched off. To use this functionality, connect wire 5 to the WHT/YEL wire in the window control harness (DONT CUT THE WHT/YEL WIRE, just tap it)
    ENJOY - comments and questions more than welcome
    My Cars: 2006 Ford Freestyle - 1990 Accord EX - 2001 Accord EXV6 Coupe - 1967 Impala "Metallicar" (for the wife)
    Vid needed! I gotta see this done!
    Members Ride Thread: LX ~ EX ~ For Sale Thread
    Sold to: accord=inspire? ~ Accord214 ~ Raf99 ~ daheavyking ~ OHOYAMA ~ JunyAccord ~ CBsevenTUNER
    Bought from: Joshy ~ TypeG ~ agol ~ 92smokeaccord ~ Extacee ~ mak ~ lindiz ~ illestatus ~ F20A CB7 ~ accord=inspire? ~ marcusv8thunder
      Originally posted by lucifer1 View Post
      Why are you using 6 relays when you only need 4?
        You only need 4 relays.
        All you need is one relay per direction per window. 2 for up and 2 for down. The window motors rest at ground on both sides. You remove ground from one side of the motor and apply 12v to move the window. To move the opposite direction you remove ground from the other wire and apply 12v. The alarm ext triggers relays to do this. This does not interfere with normal operation when the key is on.
        wire relay up as
        85 12v
        86 alarm ext
        30 motor
        87a switch
        87 12v
        This is still a bad idea in general since when windows are open at different heights, it damages the motors keeping power on when they are fully up/down waiting for the others. Just buy a 530t.
        Manual Belt Conversion-Variable Intermittent Wipers-Steering Volume Controls-Rear Defroster Antenna-JDM Climate Control-MDX Steering Wheel-Lighted Mirror Switch-CL Trunk Solenoid-CL Homelink-Shaved Hood Squirters-Foglight Wiring Diagram-Door Panel Removal-Puddle Lights-Ambient Lighting-Door Speaker Install-Window Seal and Regulator Cleaning-Prelude Cluster-Mirror Tweeter Pods-Illuminated Window Switch -More Coming Soon
          i chose the six relay method because when people bother me about how i did it, six just seems a lot cooler when im sketching out the diagram
          i will get a vid up tomorrow
            here's a quick vid of the relays in action.. a better vid when my camera is charged perhaps..
            http://www.youtube.com/watch?v=5TQlJV7klIc
              wow , the cb chasis just keeps getting better and better with time..lol
              Great job !
              Check Out My Work In Progess . . . . .
                Great job !
                I agree!!!!!
                My coupe!!!
                Originally posted by Racer_XXX
                  nicely done man... good job!!!!!!!!!!!!
                  JDM Parts for sale
                    great
                    Originally posted by Uncle Willey
                    When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
                      ahh snaps it tight lookin
                        hmmm thinking about doing the same on the cd5
                          Oh steve! You so need to to this on my cb man!
                          1992 Accord EX-R Coupe [Mat Black] Sold
                          1992 Accord EX-R Coupe [Rosewood]
                            got any pics of the install?
                            MRT: http://www.cb7tuner.com/vbb/showthread.php?t=196248
