Old 01-12-2018, 08:50 AM   #1
BreckAConner
BreckAConner is cool... so far.
Wiper Squirters clogged
Good morning,
I purchased last year some OEM wiper squirters for my CB. Shortly after they stopped working on the passenger side. Now if I power wash the hell out
Of them they will squirt again. Long story short are there any better squirters out there I can use?
For Sale Thread CLICK HERE!
1st - 1992 CB7 LX Sedan --> Sold
2nd - 1991 CB9 EX Wagon
--> Extra
3rd - 1990 CB7 EX Sedan --> Totaled
4th - 1990 CB7 EX Sedan --> Daily
5th - 1990 CB7 LX Coupe --> Sold
Other - 1983 VT750c, x2 1997 RA1 LX & x2 1997 RA1 EX, 2001 BB6 Base
BreckAConner is offline   Reply With Quote
Old 01-12-2018, 02:23 PM   #2
Crankshaft
Crankshaft is cool... so far.
You can use a pin or needle to remove the buildup on the squirters, do not be afraid to shove it in the holes as hard water deposits mixed with the chemicals is what causes that blockage. But no, you do not need to get new ones just unplug them.
Old 01-12-2018, 02:53 PM   #3
Rilas
I thought we could get squirters from an Odyssey? that have a fan pattern instead of 2 jets. It's been awhile since I ran across it on here though.'
Otherwise just shove a paper clip or something else small in them. It's also how you can adjust the jets, stick in small object and pry it, eventually the jets will break free and you can adjust them.
Old 01-12-2018, 03:34 PM   #4
cp[mike]
ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
^ this. I think also newer CRV ones would work. You can tell by looking at them - if they are similar sized and have a single output with a horizontal slit, you should be good to go.
https://www.dormanproducts.com/p-84561-47272.aspx
Many years ago somebody posted up about using old Chevy fan sprayers that clip onto the wiper arms themselves and shaving the holes on the hood. Thought that was pretty neat, but required a lot of work.
- 1993 Accord SE - Gold coupe
- 1999 CR-V EX - Daily driver
Old 01-12-2018, 03:40 PM   #5
excalibur02
Wanna be JDM whore
yeah I have CRV squirters in my red sedan.
When I find them blocked I just remove the squirters, put them in vinegar and use a small threading needle to push out any build up in the whole. I then wash them thoroughly and blow to make sure it squirts good.
Instagram username MAURO02
Old 01-12-2018, 04:53 PM   #6
fleetw00d
If you use a pin to open them up, ideally you need to remove them (or remove the tube) and blow them out backwards to try to blow the debris out, otherwise it stays inside the squirter and is likely to end up back in the hole again.
Mine don't work because when I fill the tank, it just flows out onto the ground; I just haven't made the time to remove the front bumper and find out what's going on. I'll have to check how much access there is by pulling the fender liner back.
90 LX 4dr 5 spd 366,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
93 LX wagon auto 247,000 MRT:http://www.cb7tuner.com/vbb/showthread.php?t=208490
92 EX coupe auto 168,000 - MRT:http://www.cb7tuner.com/vbb/showthread.php?t=205114
LOTS of CB7 parts for sale http://www.cb7tuner.com/vbb/showthread.php?t=192583
Old 01-12-2018, 05:18 PM   #7
NH-503P-3
NH-503P-3 is cool... so far.
What year CRV’s do the squirters come from? I’ll grab some at pap this weekend.
Old 01-13-2018, 12:04 AM   #8
BreckAConner
I'm going to check those CR-V squirters out. I wonder if they will work better than the CB ones.
--> Extra
Old 01-26-2018, 04:30 PM   #9
zedjr10
zedjr10 is cool... so far.
Exactly what i do. Then after installing them use a small pick to adjust the ball to squirt where u want. These squirters work pretty well. JY has lots of them. I get replacements when i'm there mostly cause of the hood gaskets on them get broke. Be careful with the pick inside of the ball joint thingy as i have found trying to clean them that way can mess them up for some odd reason.
Old 02-19-2018, 08:57 PM   #10
fleetw00d
Confirmed the above today. The gasket between the pump and the tank was leaking - installed another tank. Removed the nozzles, used a pin to clear them, then blew them out backwards with air - I was really surprised by the amount of junk that came out. With the nozzles off, I ran the pump briefly to clear the lines - more crap came out. Everything works now, but I have a leak in the bellows from the fender to the hood; it is still available from Honda (I'm sure I have one around - just can't find it).
