has anyone mounted up racing seats in there cb's? if so how did you mount the belts or the factory belts? i just bought some seats today and there is nowhere to put the factory belts?
racing seats?!
http://www.wedgeengineering.net/
thats where i got my brackets for my sparcos.
how much? give them a call. there cool.
your welcome.
Ebay seat mount
Used these....of course they aren't stainless steel, and needed some work to fit and work correctly, but for under $40 shipped, they did the job.2003 Maxima SE Titanium Edition
Polished Titanium ext, heated black leather int, heated leather steering wheel, HIDs, 255bhp, 6 speed, 15% tint.
1993 Suzuki GSX1100F 136bhp
Originally posted by UrDoneSRHif u got new racing seats with 5 point harnesses your going to need to put a bar going across the floor behind your seat or from the rear strut tower bar.
stop giving false information otherwise you may be to blame when he crashes and snaps his spine.
Originally posted by wed3kyou dont mount harnesses on the floor other than the 5th belt.
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
I piss off people for fun.
IA 08 Sunburn Victim #1
Originally posted by wed3knever exceed this 45 degree angle. this is how i had mine setup except i was jsut using a stock seat.
45 degrees down? Why?
How about ZERO degrees down, so no downward load is applied to the spine in the "Big One"?2003 Maxima SE Titanium Edition
If the seat reclines, stock seatbelts are OK. If it's fixed, may want to look into getting a roll bar. In the case of a roll over, a fixed seat will usually hold you upright instead of allowing you to lean sideways.-Kevin
1988 Honda Civi- D15B VTEC Dac Biet, my "race car"
1992 Honda Accord LX: DD until I finish school
Originally posted by b3nsonxyou cant really have 0 degrees down unless you use a harness bar or mount it higher, right?
that really sucks because you loose the use of the back seatsLast edited by K2e2vin; 12-11-2007, 03:03 PM.-Kevin
i really want to use reclining racing seats with the harness, because i got those automatic seat belts, so they suck. and once i remove my seats, the stock belts are gone anyways, so i gotta use the aftermarket harness.
Where could i mount my harness without losing the use of my rear seats? and still keeping it safe without breaking my spine in an accident. 91 accord coupe.
