Obd2 H22
    Obd2 H22
    So I'm looking into my first swap and have my eyes on a H22a Type S 97-98. Now I would assume because it was made when it was, it will be OBD2? I'm not sure what is entailed to swap this into my CB7. I'll be doing the swap myself and hopefully relatively soon. I looked through a couple of the swap threads but they didn't go over OBD2 H22's. Any insight would be great, thanks.
    the h22 type s is a obd2 motor. you will need a obd2 to obd1 swap harness. check out the f20b threads since its basically similar motors.
    miss my turbo cb7
    moved onto volvos. dont know how that happened, just did
      excellent, thanks a lot man. I found a couple F20B swap threads. Rather than switching components over from OBD 2, like you suggested I'll invest in the harness. I found these jumpers. From my understanding. Hypothetically I would drop the Type S motor in, and use jumpers?
      http://www.honda-tech.com/showthread.php?t=2188598
      and what is OBD2a vs. OBD2b?
      I would use the OBD2 ECU?
        http://www.phearable.net/shoppingcar...per-p-102.html
        thats not going to work. its for d and b series distributors. ill see if i could find you one.
        miss my turbo cb7
          I thought there were driveshaft size issues with the Type S tranny? Have you found a way around that?
            i dont think there would be.
            miss my turbo cb7
              you will either need to wire it yourself, or pay hasport 300 bucks for a conversion harness.
              miss my turbo cb7
                haha says right on the front page.. I guess I got too ahead of myself
                  http://www.hondasociety.com/board/sh...ad.php?t=61998
                  he says you could run a obd1 distributor. id just covert the type s into a obd1 and run a civic p06 ecu and call it a day.
                  miss my turbo cb7
                    damn, on ebay the H22 OBD1 dizzy's go for $120. I suppose I could do that though. Grab some injectors a chipped P06 and "call it a day." Then I could use my stock harness. I thought there was more to it than that.
                    Thanks a lot for your help man. I guess the best way to get this done and learn would be to go ahead and start spending money until it runs right haha
                      Nevermind. I was thinking of the SH tranny with ATTS.
                        M2B4 LSD tranny fo me
                          yea from what i've read, its easier to get a P13 which is obd1, get od1 injectors, and the rest is wiring thats fairly easy, vtec and knock sensor i believe.
                            welcome to the 97-01 prelude engine owners club
                            anyways youll need...
                            1.92-96 h23 dizzy/92-96 h22 dizzy if your external or a dizzy from a DOHC civic SI from the 90's of your internal
                            youll also need...
                            2.your old fuel rail
                            3.92-93 h22 fuel injectors/ or the pig tails from your 97-01 fuel injectors (if you do this bypass the injector risstor)
                            4. some pig tails from the 97-01 harness
                            5.P13 from a 92-96 USDM prelude or a 92-01 JDM prelude
                            from what I hear japan didnt go OBD2 till about 2000. so if your engine is 97/98 & JDM, chances are its OBD1
                            93 Accord LX Sedan (sold)
