JDM Heater Core
    JDM Heater Core
    Hey all,
    Requesting a photo of a JDM heater core with air mix motor for my DCC build, im in australia so RHD is no problem, but i just need to be able to confirm im getting the right piece when i order it. Cheers!
    sold! But here's my build thread for those interested.
    Granted this is a LHD air mix box. But here is the air mix motor mounted to the box.
    Air Mix Motor 1
    Air Mix Motor 2
    As you can see JDM heater core cover had to be trimmed to fit the USDM heater core. You shouldn't have this problem. Also you might just be able to bolt down the air mix motor, since your RHD. Yours might really just be plug and play, where the USDM cars have a ton of modification to make this all work. If you want to look at other pictures I have of the install, check out my members ride thread. It has pictures of the entire process.
      The man himself!
      Yes I've been reading all about it. Just picked up a near perfect condition controller unit for 2000¥, not including shipping and stuff. Will probably work out to around $70 USD, so finally getting around to doing this. .
      I appreciate seeing the lhd motor setups but I'd really like to see and OEM Rhd one, because I almost accidentally bought a standard heater core because all of the description is in Japanese!
        Hey guys, for anyone looking for the RHD version, heres the unmodified OEM version with my Controller, these parts just came in today, the Cable on the right is for the fresh air switch.
          where did you get your set up from? you have a contact or them I want a full rhd set up like that one .
            It's only half the setup, still waiting on a harness and sensors (going to try and use a 94 prelude setup)
            I found ex yahoo Japan auctions and used an online importer to get it in. I used jessestreeter.com
