I have a f22a1 and boosted 12lbs and I'm try new ecu's I have a h22 ecu a ls ecu and a gsr ecu they all run the car but rpm does not change still red lines at 6500 ? WTF ! Why the gsr ecu alone show hit like 8000 please help . Just trying to change redline don't care about check engine light
Getting higher rpm?
First off you need an tune to dial in your motor. An ecu change will not do anything to your redline unless you have dyno'd your. Does any of your ecus have a chip in installed in them I only ask b'cuz you did not mention it.
If you don't have a chipped ecu I suggest you get one chipped and run hondata s200 or s300
Oh and the reason why you can rev to an higher rpm is b'cuz you have cel light on and the base map for the ecu's are for stock untuned cars.Last edited by Darkcloud; 11-12-2009, 04:00 PM.
