clear sight tube hose
    would anybody happen to know if sight tube handles heat?
    i would like to add a piece for looks on the radiator hose
    i know the killerglass has it. i was just wondering.
    thanks
    Should be able to handle the heat if its meant to be used as that. Where will you be getting it from??
      it is a nice idea, once you do it show us some shots
        If the tube isn't made for it, don't do it. It's not just the heat you have to worry about, but also the compatibility with the coolant. If the coolant corrodes the hose, you'll soon develop a major leak. Not to mention the contaminants in the coolant as a result of that corrosion.
          clear hose
          i work at a tactor supply store and we have all kinds of clear hose. i found one that is rated at 150f but not sure how hot it will get.. and also like you mentioned^^^^ what if it corrodes.. ill try and let you guys know
          thanks.
            thanks.
            I don't know if I would trust 150 F. If it gets hotter and gets soft the pressure the coolant is under would cause it to expand and possibly blow. It would also probably be a pain to work with on a cb7 because the hoses have so many bends in them. IMO paint your hoses neon green, same effect.
              yea i thought about it..i read that they can go up to 190 or hotter.
              soo ill keep looking
                I know theres little inserts that clamp on to stock rad hoses. Look pretty cool. Ive been wanting one but not sure where to source one
                  killerglass.com
                  they got one for 100 might get that one sometime soon
