a little more progress
    foglights installed in bumper and bumper is on, got the engine started, no spark in cylinder 3, checked every possible solution and turns out the distributor was bad after testing a friends dissy from his h22 cb7, new dissy is on the way
    [/URL]
    need to sort the driver side chassis harness and tuck it like the passenger side, still need to wire the fog lights up, so that they actually function with a switch, its been a long process but im finally seeing the light at the end of the tunnel
      She's a beauty and you can definitely see the work put into it.
      Originally posted by Uncle Willey
      When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
        Looks good man!
          Nice,Very Nice! Will the pink be staying?
