relocating battery.
    relocating battery.
    Hey guys is there a DIY on relocating your battery to the trunk. Thanks.
    yes sir
    ^^click it or ticket^^
      positive battery cable runs from positive post to the starter and splits from that wire to the fuse box, negative you can just jump off to a bolt in the trunk somewhere I can throw up some pics of mine if you want
      CHRIS (◣_◢)
        19TcappaLX
        yeah let me see those pics. it sound pretty EZ.
          http://www.cb7tuner.com/vbb/showthread.php?t=109732
            19TcappaLX
            thanks for the help,so no inline fuse is needed.and 2 gauge cable is best and a box for the battery.
              actually zero guage wire is best. No inline fuse is needed as long as the wire is good enough.
              Also, make sure you make yourself a positive and negative terminal block under the hood; this will come in handy when you have auxiliary items to connect on to the power.
              Best is a sealed, no maintenance, battery; if you have a non sealed alkaline battery, you need to pick up a sealed box and a ventilation tube.
              DEVOTE
              FS: Lokuputha's Stuff
                I used 2 gauge cable that I bought from advance (under 2 dollars a foot), got the battery box from walmart, and used quick disconnect ends just for my benefit...the whole project cost about 30 dollars and made the engine bay look alot cleaner...sorry I haven't been on here in a few days if you still want some detailed pics I can take some and post them up for you its no big deal
                CHRIS (◣_◢)
                  i would like pics just to see how hard this is..i have been wannting to do this for awhile
                    tasauto.com has a kit if you wanna go the easy but more expensive route
                    USDM as F$CK
                      i want to relocate mine but i got some big ass subs in the trunk so idk how that would work out! whale penis intake
                      Ride: 2002 Lexus IS300
                        Just as lokuputha said, also run some blocks. They run about 10-20 at walmart and make life easier when it comes time to wire in a new circuit.
