Old 08-27-2018, 08:03 PM   #1
Carbonaccord
Carbonaccord is cool... so far.
Gates Blue Racing timing belt for f22 non vtec? T187R
i searched and searched for weeks and at last i got a hold of gates themselves. they told me no performance timing belt has ever been made for the f22 non vtec only the crappy Isuzu/Honda f22 engine with Vtec on the intake valves only and inferior flowing head. i just found out today that one actually does exist! Gates PN: "T187R" only catch its in The Australian/New Zealand market. if you go on Gates AU's website youll see it for the f22a Prelude S, CB and CD accord f20 and f22, and even the f22a Odyssey! there aren't many vendors to begin with.
anyone know how to get a hold of one of these belts directly? every website i tried says shipping is unavailable to me (CA,USA). i really want that belt to go on my motor that will see lots of bewst!
Carbonaccord is offline   Reply With Quote
Old 08-27-2018, 08:43 PM   #2
F22Chris
Maybe contact an Aussie dealer or member directly and see if you can have it shipped to the states.
Maybe Super Cheap Auto has it?
Old 08-27-2018, 09:13 PM   #3
deevergote
Don't call me dude.
The T187R was discontinued a few years back. Anything you find now will have been sitting on a shelf for a few years. Probably not great for a rubber product.
Honestly, if you’re building for boost, then you’re probably not building for high RPM. Any quality belt should do just fine. You only want those fancy “racing” belts if you’re going to be revving significantly higher than stock specifications.
Old 08-27-2018, 09:45 PM   #4
F22Chris
Well damn! Shows what I know!
Wouldn’t an OEM belt be just as good? I see high quality builds using regular Gates belts all the time too.
Old 08-27-2018, 11:09 PM   #5
Carbonaccord
Gates still has it listed on their Australian website for some reason. I was not aware it's been discontinued for a while. i mean I'm aiming for 450-500whp, and 7000-8000rpms. I currently have a gates oe spec belt. Just wanted something bullet proof so i figured why not. Thanks for the reply though!
Old 08-28-2018, 01:06 PM   #6
Grumpys93
So when I replaced my sisters timing belt on her civic I found that gates makes honda their belts. You shouldn’t have any issue with running a honda belt in your set up.
~Nick~
Grumpys93 is online now   Reply With Quote
Old 08-28-2018, 08:28 PM   #7
sonikaccord
Yep. Gates is one of the OEM suppliers for Honda timing belts. They are bulletproof as long as you don't improperly tension it or run high lift cams at high rpm.
Old 09-10-2018, 06:08 PM   #8
Carbonaccord
I actually contacted some vendors over in Aussie and for sure they are discontinued. Whatever is left in stock will dissapear forever once sold. i got a hold of one for 64 USDshipped to my door! (Cheap!! ) which was 97 AUD. So i did get a hold of a belt and it appears to be in excellent shape. i mean these things are meant to handle extreme temps after all. this will be the only belt I'll ever buy however, since by the time it needs replacing ill be messing with another motor, likely a sleeved and fully built H series.
Old 10-10-2018, 08:53 AM   #9
dreamability
dreamability is cool... so far.
What vendor did you go through?
dreamability is offline   Reply With Quote
belt , blue , gates , racing , timing
