Old 09-01-2018, 04:39 PM   #1
Carbonaccord
Carbonaccord is cool... so far.
Question 1400cc High Impedance injectors and p28 Hondata s300v3
Question for you guys. Ive done plenty of searching around and i think i know my answer, but id still like to confirm with someone who knows for certain since ive tried searching and havent found very many threads as far as injectors and the resistor box.
So my situation, i have 1400cc Five o Motorsports Black ops injectors (purchased from Bisimoto and are e85 compatible). in short they are High Impedance (12 ohms) and stock is low impedance. Do i simply delete the resistor box for these to work? Is it as simple as soldering the correct wires together? If so which ones to which? Theres one red and 4 black wires. I dont want to ruin my ecu as it cost me a pretty penny from HAMotorsports. My ecu is an obd1 p28 with Hondata s300v3 for my boosted application. Thank you guys!
Carbonaccord is offline   Reply With Quote
Old 09-01-2018, 05:28 PM   #2
Raf99
I'm not 100% certain but my thought was yes. I remember reading it was an OBD1 thing too. But wow, you're going to want to find out for sure. You'll need some Yoda honda master who knows 100%. I thought it was delivered via the ECU and if you have S300 you can set this.
Old 09-01-2018, 06:51 PM   #3
tutsuo
tutsuo tutsuo
i thought f22 stock resistor box was 12ohm... ?
i have 1000cc high imp injectors and in neptune if i run the 2ohm my car wont even start. i use 12 ohm and boom easy.
Jesus drove a Honda, he just didnt talk about it like us. Proof - John 12:49 "For i did not speak of my own accord."
den das al u ned u no dat u get wurs gas milge tho rite?
tutsuo is offline   Reply With Quote
Old 09-01-2018, 10:44 PM   #4
Grumpys93
http://help.injectordynamics.com/sup...y-id-injector-
You will find your answer there. Or you can get a resister box from the junkyard cut out the plug and solder all the wires together on the plug. You then created a jumper that can allow you to revert back to stock if you ever need to by simply removing the jumper plug. That’s what I plan to do.
~Nick~
Old 09-01-2018, 11:07 PM   #5
Raf99
Yep, that's what the injector sees.
The resistor box gets 12V and the resistors step it down to 12 Ohms. This will vary but all one needs to know is that there is low and high impedance which usually correlate with OBD1 and OBD2 I thought S300 it's just a checkbox. You just set the injector settings to what spec they are.
http://www.superstreetonline.com/how...-resistor-box/
Old 09-02-2018, 07:48 AM   #6
GhostAccord
Low impedance, peak and hold requires a resistor box. They are available in both OBD1 and OBD2.
High impedance, saturated, do not require a resistor box. They also come in both OBD1 and OBD2.
by GhostAccord, on Flickr.
I was actually quite impressed when I googled injector resistor box and found my wiring diagram on a number of forums and tech websites. Not sure that any of them ever asked me for permission to use it, but hey it's out there!
MR Thread
GhostAccord 2.4L Blog
by Chappy, on Flickr
Old 09-02-2018, 12:34 PM   #7
Raf99
Interesting , thanks Ghost. I always through OBDII never came with low impedance, good to know. I'm assuming no newer 2010+ vehicles use low impedance now though? Nice diagram too!
Old 09-02-2018, 01:58 PM   #8
GhostAccord
As far as I know the 97 Accord, Odyssey and H23 Prelude were the last to use low impedance 240cc injectors. The early F23 might have as well????
Here is a good article on what the differences are.
https://www.hondata.com/tech-low-hig...ance-injectors
MR Thread
Old 09-02-2018, 11:54 PM   #9
F20BturboCB9
F20BturboCB9 is cool... so far.
I have ID1000 injectors and they are high impedance as well. I ended up using one of those splice pack connectors that GM used on their data lines to separate modules when diagnosing communication problems. Just de-pin any extra wires and use heat-shrink butt connectors to connect the 5 wires. It will be nice if you ever have to diagnose injector issues, plus it looks cleaner than just soldering them all together.
F20BturboCB9 is offline   Reply With Quote
impedance , iniector , resistor
