Got home late yesterday and didnt have time to check. Today ill be giving fuse #23 a pull and. See what happens. If anyone has any other ideas feel free to chime in. Or if you know which wire i can throw a switch on and atleast be able to turn off the lights when i park instead of having to disconnect the battery after every stop i do for work which is one every 10-20 minutes.
91 accord daytime running lights stay on with key out
Originally posted by Dabsfordaze View PostGot home late yesterday and didnt have time to check. Today ill be giving fuse #23 a pull and. See what happens. If anyone has any other ideas feel free to chime in. Or if you know which wire i can throw a switch on and atleast be able to turn off the lights when i park instead of having to disconnect the battery after every stop i do for work which is one every 10-20 minutes.
Originally posted by visualpoet View PostFollowing. I'm having the same problem. I pulled the small light fuse under the hood. Lights are still on.
