turn signal no more
    turn signal no more
    one day driving the road put my turn on and got nothing. i have changed the switch, relay, and the hazard switch and bulbs and still no turn signal, what is going on ?
    Did you check the fuse? Is anything else not working?
    YouTube Clicky!!
      Usually that means its a fuse...
        I changes the turn signal�� relay, the hazard switch and I couldn't locate a fuse uber the Hood or side panel and bulbs and got nothing
          The fuse is there. Is anything else not working? That will tell you if it's the fuse. You may also have a bad ground(not likely).
          YouTube Clicky!!
            It is fuse #20 under the hood box. It is a 10A fuse.
            Black Housing DIY 1991 Wagon Morimoto Retrofit
            JDM One-Piece Headlight Lens Repair
              Get a multi meter, turn the hazards on, check for power at the socket. Turn the lights off, and check resistance(ohms). Get a test light and check your fuses.
              Basically just make sure you have power to the light first, then go from there.
                What F22Chris said. The game when chasing down an electrical issue is dividing the circuit up until you find the line between the way it should be and broken. Whatever is in between is what's bad. I usually start by testing wherever is easiest to reach, like the fuse panel and bulb socket.
