If your F22 is in a project car, and you can afford the time and money to blow it up, go for it! If meth injection really will extend the life of a stock-internal F22A, then at least that's another option to suggest to people. Some people just refuse to open the engine (I think it scares them), so they only notice the stock-block turbo setups that haven't blown up (yet), and ignore the warnings of others. I suppose it would be nice to be able to say "you could at least use a meth injection setup to keep it alive a little longer!" (even though a meth injection system will usually cost just as much as a set of inexpensive forged pistons, and require nearly as much learning and wrenching to install properly!)
I'm curious to see your results. I say give it a shot. If it blows, it blows!
