so my a1 has been running a little rough lately.. i have been babying it and need it to last til i finish building a a6 to drop in.. today after work i was getting on the highway and had to gun it a bit.. right around 4.5-5k the rpm needle jumps sparatically.. tha was second then in third it did the same thing at around 3 and a half. any ideas on this?
rpm jump
well ignitor is new.. and i duno aobut the distributor..or alternator.. i put some new plug wires on last night tho.. but its done this b4 i got them so its not that.. but i mean my engine is kinda beat.. it burns oil and i think its the valve guides but i duno how to tell.. so i was thinking this rpm thing had something to do with that.. or like a fuel cut or something
when my "idle" was jumping, it was purly due to the "cold air" sensor. mounted on the front of the intake mani. has a couple of coolent lines going to it. and one electrical plug... its actually a "two peice" unit. what happens is, is there are a series of "o" rings made of rubber. they keep the coolent in the area's that it needs to be in, to work proporly. the "o" rings get hard, start to break down, then the next thing you know, is your jumping idle. it lets the ECU know when to kick down to warm operation mode. and right now, it seems to be confused...
well i hope that was your problem..
if not, well atleast i was the only MOFO willing to give out a suggestion...
take it easy Joe...
Originally posted by snailin91slack in your TB cable.. jamb nuts may have come loose, there4 the TB cable comes loose. so when you "jack" the throttle, it will hesitate for a second. mine did the same thing. and it ended up being the cable. that was after i had fixed the other problem of idle jumping...
hmm that very well could be.. i was messing with it the other day and i over tightened it and it was messing with my shifts so i loosened it back up a bit.. so i thought i got that right but ill have to check that out too..
the way i adjusted my "TB" cable, was started it, loosend the pinch nutz. pulled the slack out enough to pick the idle up. then backed it dwn just a bit... took care of my ish. b4 i would go to grab 2nd 3rd or 4th, and it was a huge power drop for a second or two... check it out.. never hurts...
Originally posted by jdmaccord91mine was doing the same thing, it was the ignitor. not that it was failing but that the wire connections on top, one was almost off. pull the cap and check them out
