1991 coupe jerks alot while slowing down 5 speed
    When slowing in my 5 speed car starts to jerk back and forth. It seems to happen in just about every gear from 3000 rpm down to 2000rpm. Now I know it's the same feeling like when u let your clutch out to fast and don't give enough gas the car bucks and jerks you all over. Well I've never had any 5 speed do this to me in these rpm range before. I have always had a clean feeling slowing down and now this
    check for vacuum leaks
      If by a jerk you mean like a shake feeling of the engine when you press the clutch (up/downshift) then you should check your motor mounts. Try that.
      '09 Mini Cooper S (R56)
        x2
        http://www.cb7tuner.com/vbb/showthread.php?t=194049
          It's a bucking feeling when going down in rpms. Ill check for vacuum leaks tommarow with smoke machine. Motor mounts are good
            QuikQuestions: When did this start, How long has this been going on, and When was your last transmission fluid change?
            "There are only two types of people in this world... Those who run & win, and those who sit at the sidelines & watch the winners pass them by."
            My YouTube Channel! - There's more videos here!
            Check 'em out, hit LIKE, or even better, stay updated with more vids when you SUBSCRIBE, including vids of my JDM H23A swap!
