Originally posted by B20F22A1
Common terms being tossed around i.e. P06
I had written this article a while back for my old blog, might be useful to some people.
Chipped Honda ECU Myths
Originally posted by MRXit's retarded to take a vtec ecu and make it non-vtec. A pure p28 will go for a lot more than a p28 with no vtec. How about this, trade me the p28 for a chipped non-vtec ecu of mine with a lot cut off the price. That way you aren't wasting a perfectly good p28 that I or others could benefit from.
http://cgi.ebay.com/ebaymotors/ws/eB...TODAY.m238.lVI
hope fully i can start tuning soon just need the wideband and gauge(inform me anybody if i need any other products very intrested in starting to tune
Originally posted by MRXThe pt3, pt6, p0a, p14, p13...they are all chippable but companies like JET and Gude are the only ones that have figured it. I can chip things like the p14 but i can only turn off the speed governor and knock sensor...maybe an 02 sensor. The programs are locked so I can't even modify the fuel and ignition curves. The accord and prelude ecu's are limited. The fuel and ignition maps for them look INSANE and last time I checked none of them could accept more table values for boost or nitrous.
Cuz i plan on keeping it AT, and my only concerns would be the knock sensor and governor.
PS: MRX, YGPM
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
A p14 will run your motor like it's meant to be ran, with the knock sensor properly hooked up.
A p06 won't run your engine as it should out of the box. You will have to get it tuned.
Chipped ecu's aren't just a plug n play thing. For a lot of people, it has been, but most always get theirs tuned.
Also, if you would have researched, you would have found this
http://www.cb7tuner.com/vbb/showthre...highlight=auto
I hadnt come across that yet...
Im curious as to how well the H23 would run with my pt6... Doubt it would last very long.
Yeah, ATs arent worth tuning, but since im doing a swap, im gonna need a chipped ECU....or am i?
I dont want alot of fancy add-ons and what-nots, just your typical bolt-ons. I just want the engine to run properly....or as "properly" as possible.
But if i have to run a chipped ECU then i may just have to get the p14 and find the guide for the knock sensor.
I didnt know that ECUs were as interchangable as they are. Now i that i know that, i see it doesnt really matter. Im only leaning towards the p14 because its the ECU the H23 is used to.
so as i read you say that any ecu can be made to run as anyother ecu...?
i have been looking into getting a p72 chipped and basemap is 250 for it all but at a the jy there are a couple im goin to check in on.
i have a h22 and wanna run the secondarys can this be done on a p28 or do i need to go to a p72?
How much are you willing to spend. Its as easy as that. p06 can convert to a p28.
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
I piss off people for fun.
IA 08 Sunburn Victim #1
well that what im wondering. would it be cheaper to buy a say p28 and add iab's and chip it with the h22 base map or say buy a p72 and just chip that?
money isnt a huge issue i wanna spend what will get it done right but not a huge amount. i found a p06 chipped for vtec for 170 and a virgin for 60 and a chipped p72 for 250 with basemap.
Originally posted by F22Cb7Rid3rwill some1 buy me a book. ecus for dummys! cuz i have no clue what ur taling about.. but i wanna get rid of my speed govener how do i do that? i have a f22a1 also whats a knock sensor? dont mean to sound lieka nub but i just dunno what all this stuff is and im curious lol
read up on everything you can. thats how to start to figure things out. and im not sure about how to remove the govener. the programing is past me ahah sorry man.
as for the knock
The knock sensor is used by the ECU to retard ignition timing when it detects engine knock, or pinging. With a stock ECU the knock sensor is not used over 5000 rpm, as engine noise masks the sound of the knock. The knock sensor is often confused by after market pistons, which have larger clearances than stock pistons, so is it best to disable on engines with after market pistons.
copied from the hondata website.
