Go Back   CB7Tuner Forums > Beginner forum -- New members post here! > Beginner "Off Topic"
Old 10-10-2011, 09:20 PM   #1
Grafikz
Grafikz is cool... so far.
Drop Max?
Im curious to how far sum people have been able to drop cbs without running into issues. I plan on going 17s MAX but more likely 16s. Plus I live in the south so no big pothole. And I live in the suburbs so no dirt roads. Im not looking to totally slam it and I've taken measurements and I think 2inches should b gud but id like to get sum opinions before I make the buy/install.... thanks much
Grafikz is offline   Reply With Quote
Old 10-10-2011, 09:25 PM   #2
Darkcloud
Darkcloud is cool... so far.
Go 3in, I have no probs as of yet, its all about the streets and how cautious you are
Others have been super slammed. No point really cb7 tilidie is slammed to the max
Darkcloud is offline   Reply With Quote
Old 10-10-2011, 09:31 PM   #3
Grafikz
Thank you much. But now im sad all I can find are 2.25in drop kits lol
Old 10-10-2011, 09:33 PM   #4
crazymikey
crazymikey is very helpful crazymikey is very helpful
First of all, there's lots of choices out there.
You can go with the highly NOT recommended coilover sleeves and struts, which are guaranteed to either kill you, or someone in your vicinity on the road.
Lowering springs installed on stock struts. Not highly recommended, but most of the time you can get away with it.
Proper lowering spring/performance strut combo. Cost effective and safe.
Full coilover setup. Expensive and more race geared than street driven, but many of us run full coilover setups, since a good set can be had around $600, and is marginally more than a good spring/strut kit.
Always worth upgrading your suspension bushings as well. Then there's adjustable camber kits as well, and wheel spacers and all sorts of stuff to play around with for lots of adjustment.
Examples of drops;
1.75" drop on stock wheels. These are just lowering springs on stock struts. This setup has been on this car for almost 2 years.
Cheapo-going-to-kill-you coilover sleeves on stock struts. Way too freakin low. These did actually fail on me on the highway and nearly caused me to crash.
crazymikey is offline   Reply With Quote
Old 10-10-2011, 09:38 PM   #5
jewelproject
jewelproject should be shot. jewelproject should be shot.
this is a 2.5 drop on oem 6 spoke 15s. might give you an idea how far you really want to go. just remember your downpipe will take a beating to dips and shit in the road when your really low.
RIP 4/23/12...lets not forget, the 88" Z31 turbo, are my dailys
jewelproject is offline   Reply With Quote
Old 10-10-2011, 09:40 PM   #6
Grafikz
Thank you. Ya I didn't plan on lowering it yet but the struts are going out so I might aw well. Thank you again so much insight!!!!! Love it. Its my daily driver so im think 2.25 should b gud thanks guys and the pictures helped me get an idea of wht im looking for! Thank again! And also I've got a slider plate already installed to protect my downpipe. I recommend it
Old 10-10-2011, 09:45 PM   #7
crazymikey
Good idea on the slider plate. You'll find depending on the drop, your front lip, downpipe, flexpipe or muffler will drag or get caught up sometimes.
Old 10-10-2011, 09:46 PM   #8
TracieS
TracieS seems to have made some friends! TracieS seems to have made some friends!
this is a IDk drop well over 4in lol but I have monster truck tires and don't rub at all so a 15 with thick tires is like a 16 or 17 with low pros.
STANCE|WORKS
TracieS is offline   Reply With Quote
Old 10-10-2011, 09:50 PM   #9
Grafikz
Thanks! THT LOOKS INSANE!!!!!!!
Old 10-10-2011, 10:08 PM   #10
Juicebox00
Juicebox00 is cool... so far.
If the frame is touching the ground, you're at the max....and should raise it up a hair if you can get a jack under it.
Juicebox00 is offline   Reply With Quote
Old 10-11-2011, 12:12 AM   #11
deevergote
Don't call me dude.
Keep in mind that the lower you go, the more consideration you'll have to take in terms of camber correction, clearance, tire wear, cost, etc... Also, there is a point of diminishing returns... basically, lowering a car a little will improve handling and performance. Lowering it too much will cause it to handle terribly, to the point of being unsafe.
Whatever you do, get quality components... and DO NOT drop your car on stock shocks. You will need shocks that can handle the height, as well as the spring rate. If you do not understand these things, I suggest you do some serious research before you touch your car. Your suspension is one of the most important parts of your car, as your life is riding on it. If you don't modify it carefully, you could be risking your life (or the lives of your passengers, or anyone in your path when you lose control.) Not worth the risk to make your car look "cool" (personally, I think a slammed car looks broken... A 1.8-2.2" drop looks nice.)
Old 10-11-2011, 12:37 AM   #12
SOHC-FTW
SOHC-FTW seems to have made some friends!
I'm right there with mike (I believe is deev's name ha) it's pointless for daily driving.I'd say 2.5 is max drop for me i've did the slam business looks ok, but on real roads it's crap.If it was a super car i could see it, but i don't think you will see a 180mph accord on the track anytime soon even lowered 4inches.
02 Crv
SOHC-FTW is offline   Reply With Quote
lowering kits , suspension
