I know i can use an h23 crankshaft to make my f22 2.3 liters but would a f23a6 crank work the same and still be reliable under boost (20lbs or so max)?
I ask because im building a turbo F series for my EF and i want to see if i can utilize any parts from this f23a6 i got out of the dumpster at work thats otherwise good except its got shitty rings and the vtec solenoid is out.
Also What bearings would i buy? Ones that are made for my rods or my crank?
