Electric Trunk pop
    Electric Trunk pop
    I have A electric trunk release for my alarm system, I was thinking insted of wireing it to to trunk itself could i use the pull tab there by the drivers seat or would that not work so well i was going to get some extra wire so i could mount the solinoid up into the dashboard area and run it down to the pull tab ? are there any cars anyone has pulled the whole solinoid and latch out of to make a system work if so what?
    Originally posted by evil_demon_01
    Do it once, do it right.
    Saving a dollar is not worth risking a life.
    Missing My
    White -91 LX Sedan - leather converted
    Mulberry 91 EX Sedan
    The project 92
    When i was hooking up my trunk pop, i was thinking about doing it by the pull tab. my solonoid fit perfectly inside the dead pedal but after rigging it up the solenoid itself did not have enough travel to completely pull the latch up. The trunk cable needs a good inch and a half to open the trunk. i ended up mounting it in the trunk with the solenoid cable looped directly onto the arm inside the latching component to the trunk. hope this helps
    Originally posted by Quashish
    Holy crap thats a clean F series. jellish mang.
    Quashish dictionary
    Jellish: (adjective) Jel-%i'sh+#
    To envy something to point of almost blowing a load involuntarily.
      Beat me to this idea. I've been wanting to do electric actuators for the hood & trunk.
        Had it on my old CB, just use an actuator like the one below and mount it on the trunk, to pull the rod.
        My 5.7 LS1 Holden Ute
          i don't know what brand alarm you have or the exact model of CB7 but here's what i did to my 93 coupe (Code Alarm) & a 92 sedan (Marksman Alarm)... I bought an Actuator Kit (as described by evil_demon_01)(Dan's Actuator came out of a 95 Mercury Sable Wagon, lol) & a 12VDC 30/40A Relay because chances are your alarm won't have enough "Juice" to power the Actuator, most alarms commonly have about a 300mA output. There is a spare harness behind the plastic cover of the driver side taillight to get power for the relay & so i also mounted the relay there. hope this helps!
          My 93 Coupe
          DanCan's 92 Sedan
            good to know! how long did it take to put on? seems ez
              yeah it's pretty simple! not sure exactly how long but it took longer to wire then it did to mount...
                Does that mean using power from the trailer harness? I ran my multi meter through it all and nothing had power can you explain that
                Thanks
                Missing My
                The project 92
                  Test for 12v at power antenna, if not then you'll just have to run a power wire from the fuse panel (Do you have a amp/sub installed? could run power wire from that to) whatever's the easiest way
                    cool i tested the power there and i go full time 11.86 or so but i have a harness for the antenna there aswell (i have no mast but motor installed) il try wireing it up to that for now
                    Missing My
                    The project 92
                      one of the first things i did to my CB7 was remove the antenna cause it would leak (plugged hole with a 7/8" solid grommet, lol) so now i have that harness to use at my own will...
                        My 93 Coupe
                        On this setup, could you still use the factory pull tab to open the trunk as well? Some actuators are "locked" when they are not recieving power to operate.
                          Im friends with CoOchyCB7, and both his and I manual popper still works fine.
                          Project:Black Skittle
                          AOM->April 2014
                          MRT->http://www.cb7tuner.com/vbb/showthread.php?t=199779
                            FatManChunk - There are Actuator's that Lock?!? I''ve never heard/seen this before. That could be handy in some installs! But the one's DC & I used lets the latch move freely with the Key/Trunk Release & as you see, you can use the Actuator to pull or push the latch.
                              Yea the actuators in my shaved door kit for my s10 were a "locked" style. Locked meaning without power, the motors did not move at all. Kinda like a minature linear actuator. Wish i still had em.
