J25A has a crazy short stroke of 71.6mm (which implies high domed pistons) the bore is 86mm
Has anyone measured these pistons?
I wonder if it would work okay with this setup
F23A1 block - 86mm bore, 55mm mains
F20B crank - (98+ with 55mm mains)
F20B rods -
heres part #s
13010-PGE-A01 PISTON SET (STANDARD)
13010-P8D-J00
13010-P8E-A00
13030-PGE-A01 PISTON SET (OS 0.25)
13030-P8D-J00
13030-P8E-A00
13040-P8D-J00 PISTON SET (OS 0.50)
13040-P8E-A00
F20B rods -
heres part #s
13010-P8D-J00
13010-P8E-A00
13030-P8D-J00
13030-P8E-A00
13040-P8E-A00
