Hi I've got a 93 10th anniversary edition and I have been having problems keeping a charge on my battery. I have replaced both the alternator and the battery and nothing seems to work everytime i go to Autozone to test the alt or battery they test bad in the car but in the store they test good. Any ideas on how I can fix this?
Alt not charging
Check the power to see if you are getting output from the alternator. THen check all the fuses in the fuse box. Check whats the battery voltage at idle as well.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Output is definitely low. It can be either a bad alternator, or a bad sense wire going to the alternator. Do exactly what the test shows on the previous post. It will narrow you down.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
You may have repalced with a faulty replacement unit.
I suggest to get your alternator checked by a proper electrician.
I had this same problem, checked double checked traced grounds, changed alternator etc to no avail. A proper electrician spotted my new alternator was still faulty. Third time lucky it was fixed.Rides:
Accord
CR-X
88-JDM-Si- Black
CR-X Del Sol
92-JDM-SiR "Transtop" - Black
Prelude
That's a definite possibility. A lot of people are hesitant to suspect a newly replaced part, but it's not uncommon for them to be faulty right out of the box. Especially if the replacement part was a refurbished unit.
My friend and I installed 3 different starters on his car before we found one that worked! (also from Autozone)
I have learned that the alternator is charging but I have a parasitic drain somewhere in the line because when I put the battery on the charger with it still attached to everything and test it with my multimeter it drops charge at about .01 volts/30 seconds or so. I have checked the positive going from the battery to the fuse box and there doesn't seem to be any exposed wire. So what should I try next?
and if it is the alternator.Last edited by Accord problems; 06-10-2013, 12:39 PM.this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
