Coupe Rear Interior Panel Removal Assistance
    I have an EX Coupe.
    Okay, so I'm currently working on redoing my interior door panels, but I need some help figuring out how to remove the rear panels for my coupe.
    I removed my seats, and got the 4 screws that hold in the panel
    1) Arm Handle (Upper)
    2) Arm Handle (Lower)
    3) Bottom Screw
    4) Screw near the backrest
    and the rest is clips all the way around... BUT. here's the snag:
    1) how do i separate the plastic piece that guides the seatbelt (the opening from where the seatbelt comes out from) from the panel without snapping it off? theres very little space to get behind there, and very little room to play... :[
    Questions:
    Has anyone with a coupe ever tried to remove the rear panel?
    Do you know what part I'm talking about?
    Can you provide me some insight as to how to take care of this situation?
    If I can get this information, it would be greatly appreciated. thanks!
    It's a lot easier working on the rear side panels with the bench removed.
    Try (gently yet firmly) pulling the panel out from the door jamb area. That should get a couple clips out, so you can remove the seat belt guide. Pop it out from behind the panel.
    My pictures/photos will return soon...
      i noticed they were screwed in too, would i just have to pull the panel out enough to get some arm room, and get a stubby phillips and unscrew the plastic piece off of the panel? cuz i tried to pop it off (I was at the junkyard, so i was practicing on what few coupes there were), and i didn't notice if it could or not... :[
        Which parts are you referring to?
        The top half of the panel (vinyl/cloth) is screwed onto the bottom half (plastic/cloth). You can remove the entire panel as one item, tug onto the seatbelt to get enough slack, and then pull the panel out for easier access to said screws.
          oh sick, exploded view, forgot these were around!
          #14.
            #14.
            Ah, okay.
            Well, if you don't want to pull the entire panel out, I guess you're stuck using the stubby!
              hahahaha feckkkkk! i'm rippin' that bad boy out! >_o'
              can't wait to finish this project though, i'll be thoroughly ecstatic if this turns out as i hope.
              stay tuneeedd to the MRTTTTTTTTT
              PS: your sig's tight, haha
