When my car was aligned a year and a half ago, the printout showed everything in spec. I recently replaced a tie rod and installed Prothane Urethane bushings in that corner at the same time (passenger front). As of right now, only that corner has urethane bushings, the rest are original afaik. The radius arm bushings were installed larger back, thinner front. Snugged while in the air, then torqued to ~35lb/ft after placing the car back on the ground. Alignment printout today shows 1.7 degrees caster, compared to 3.2 last year. What's going on? Do I need to tighten it further, swap them so the thinner one is behind, or what? Or do you think the change in caster is unrelated to the bushing install?
Sidenote, the steering attempts to turn to lock when driving backwards. Is this normal? If not, what's causing it? It's done it since I got the car, seems unaffected by the change in alignment. Power steering works fine, though it has a remanufactured rack.
