H23 intake manifold swap, throttle cable too short
    Hello!
    af_1132 and I just put his H23 IM on my CB7, but we noticed that the throttle cable was a few inches too short to allow the throttle to close, even with adjustment of the two adjusting nuts all the way to the right. He does not remember his being that short, so we were wondering if anyone else has come across this, and what they did to modify the cable.
    Thanks
    When I did my H22 swap I had to use reuse the throttle cable lever from my F22 on the H22 throttle body. Otherwise the cable wouldn't be long enough since the H22 lever is larger. The lever can be swapped over and I've had no issues at all on this setup.
    Euro CB7 2.2i [F22A3] --> [H22A7]
      We appreciate the help, man. I just don't remember having to do that myself when installing the manifold. I guess my throttle cable was at least an inch longer.
      MRT
      Selling on Ebay!
      15.10 @ 90.42mph
        Right, well I also recall I had to flip the cable bracket around on my Euro-R intake manifold to make the stock throttle cable work.
