It could if an injector or 2 or 3 are gummed up. Did you replace the rotor and or cap on the new dizzy? If you sprayed starter fluid and it didn’t start or do anything then your having spark issues. How did you test for spark? Are you external or internal coil? If your external then that could be the issue since that is a different component outside the dizzy.
Crank no start, fuel, spark, air, timing, and compression tested
~Nick~
I replaced the entire dizzy, it’s a external coil pack. I have tested the everything with a test light. So I tested from the coil to the dizzy got spark and I also tested from the wires to all the plugs and had spark. That is the only testing that I have done for spark but I assumed it’s sufficient.
Are you getting an injector pulse??
Edit: That was already recommended, proceed.Last edited by sonikaccord; 12-21-2018, 05:08 PM.
did you ever get this sorted out? If not, I would look at the ignition control module inside the distributor, even if its been replaced already with new distributor, if there was a big temperature difference inside to outside while the car was in the garage, that would be the reason for it starting all the sudden, hot temperatures can make the ICM fail like the main relays do, cold everthing works ok'ish, once warm it fails. The aftermarket distributors and electronics in them are starting to really cause issues beyond the normal stuff. find an original oki or nec ICM that's known good and i bet she fires right up. also any obd1 honda or acura distributor will run our F22a&b motors this includes the ICM, cant properly set timing though, example 94 integra b18b distributor works fine except setting distributor timing is impossible, I could write pages about all ive figured out with honda Dizzys. coil on plug conversion is the only way around it since OEM ICM's are obsolete.
