Go Back   CB7Tuner Forums > Parts & Performance > Performance Tech > Forced Induction
Old 01-31-2010, 09:58 PM   #1
Gtseviper
Gtseviper is cool... so far.
G22 turbo build
03/22/10 New photos and parts update
01/19/10 Parts update (full list of parts)
.63trim t3 turbo...on the shelf
Crower billet h22 rods
wiseco 4g63 evo 8 & 9 stroker pistons 1.130
civic aluminum radiator
skunk2 intake manifold
450cc injectors
turbonetics t4/t3 50 a/r, .63 trim
cash iron manifold instead
Str competition fuel rail..no go
Arp head and main studs
obx 10mm spark plug wires
emusa 38mm wastegate
Greddy type S bov
Exedy stage 1 clutch
New seals for the block and head
2.5" catchback exhaust system
ebay catch can (converted to breather by myself) with stainless steel braided lines and K & N breather filter
sandwich plate with oil cooler lines
custom gauge pods (done my me)
custom digital wideband air/fuel gauge (done my me)
auto to manual conversion
intercooler with piping
chipped p06 with vtec
Crome pro software tuning
New PICS are up on page 4 5/18/2010
New photos 03/22/10
tsx retrofit
f22b dohc boosted
custom gauges pods
Gtseviper is offline   Reply With Quote
Old 02-01-2010, 04:31 PM   #2
lilpat93accord
lilpat93accord is cool... so far.
Looking good bro..what's your power goals for this setup?
lilpat93accord is offline   Reply With Quote
Old 02-01-2010, 04:37 PM   #3
Supergenius
Supergenius may have said something they shouldn't have...
Everything looks great except for the steel wool in the CAtchcan...
GET IT OUT
!!! that's what baffling is for, and if you are going to drain that to your pan... well, hopefully you get the idea... Also a note. The baffling on the H VC is on the REAR... Should have put the PCV vents on the rear to utilize the factory baffles.... B series are on the front, thats why they do it o n the front like you have it. Its not a huge deal, but will make a difference.
I LOVE TO SEE GUYS USING THE H rods and EVO pistons LOVE LOVE LOVE it :OP
750 WHP/575 TQ CD5 Raping a street near you....
realHomeMadeTurbo.com / Kaizenspeed.com / LSD Motorsports / Tempest Racing /SpeedFactory /ExplicitSpeedPerformance
GFI HOLLA!!!!!!
http://www.youtube.com/watch?v=Cdiz0k0Rudw
Supergenius is offline   Reply With Quote
Old 02-01-2010, 05:02 PM   #4
Gtseviper
Thanks for the input guys...wouldn't the steel wool help the oil from slushing around in the can...I'm going for about 250-300 for now
tsx retrofit
f22b dohc boosted
custom gauges pods
Old 02-10-2010, 03:59 PM   #5
PR CB7
PR CB7 is cool... so far.
Send a message via MSN to PR CB7
you pass 300 with the evo pistons
at what psi will you be running at?
Just do what PR CB7 said.
PR CB7 is offline   Reply With Quote
Old 02-10-2010, 04:27 PM   #6
Gtseviper
I haven't slammed the engine in yet...I am hoping to start out with a low psi to start out with since it is my first build
tsx retrofit
f22b dohc boosted
custom gauges pods
Old 02-10-2010, 08:22 PM   #7
QUICKwitit
QUICKwitit is cool... so far.
Send a message via AIM to QUICKwitit
go with a 3" inch exhaust for one its a h22 second its turboed. The car will get better performance it's been proven in research.
QUICKwitit is offline   Reply With Quote
Old 02-15-2010, 05:43 PM   #8
dbsharp
dbsharp is cool... so far.
nice. your motor is cleaner than mine, lol!
spin city
dbsharp is offline   Reply With Quote
Old 02-18-2010, 11:00 PM   #9
Gtseviper
I love paint...lol...look at it now
tsx retrofit
f22b dohc boosted
custom gauges pods
Old 03-01-2010, 11:03 PM   #10
LoDollar92LX
Mr.Horsepower
LoDollar92LX is cool... so far.
Send a message via AIM to LoDollar92LX
i would get rid of that turbo manifold if i were you.
what HG did you use? you might have oil leaks unless you used hondabond around the ports where the oil drains from the head to the block.
instagram @mikeymeyagi
LoDollar92LX is offline   Reply With Quote
Old 03-02-2010, 12:32 AM   #11
Gtseviper
I grinded down some hex head bolts and literally slammed them down into the two unnessary head drain ports....the gasket I used fit perfect with the ports and also helped cover the un-needed drain ports
tsx retrofit
f22b dohc boosted
custom gauges pods
Old 03-02-2010, 09:00 AM   #12
LoDollar92LX
Mr.Horsepower
trust me the oil drains dont line up right on the block....
just because the gasket covers the holes you plugged doesnt mean it will seal. a MLS gasket can only seal properly on the raised areas around ports, and a h22 gasket doesnt line up right on a f block.
Old 03-03-2010, 05:27 AM   #13
dbsharp
are you running balance shaft? I know that it cost more, but you should consider deleting them. That manifold looks like a xspower part. I would recommend bracing it at the very least.
spin city
Old 03-05-2010, 08:00 AM   #14
excalibur02
Wanna be JDM whore
Any more updates?
Instagram username MAURO02
Old 03-05-2010, 08:14 AM   #15
Gtseviper
I am currently getting ready to put the engine into the car...I was working on getting the intercooler and radiator fabricated
i will weld a piece of metal to the bottom on the manifold for safeguard
I understand the oil line don't line up...I saw that for myself...the first gasket i used..was useless because I had to do to much cutting and the one above...worked a little better with the f
tsx retrofit
f22b dohc boosted
custom gauges pods
Old 03-10-2010, 09:06 PM   #16
Gtseviper
just added a 60 a/r 63 trim turbonetics to my list...lol
tsx retrofit
f22b dohc boosted
custom gauges pods
Old 03-10-2010, 09:11 PM   #17
bruno8747
bruno8747 is cool... so far.
Send a message via AIM to bruno8747
What do you mean when you are talking about slamming the hex bolts into the unused ports? I am very unclear on what you did.
bruno8747 is offline   Reply With Quote
Old 03-10-2010, 10:17 PM   #18
Gtseviper
I got some headless screws and grind the edges off because they were to big...but i left enough to use an adjuster tool (hammer) for a tight fit...then I slammed headless screws into the un-need drain holes
tsx retrofit
f22b dohc boosted
custom gauges pods
Old 03-11-2010, 08:45 PM   #19
dbsharp
even with gray rtv filling up the gap my old motor seeped oil after a while and made my block dirty as hell. The new motor is going to have matching head and block ports....
Did you jam it into the block or head? got any pics?
spin city
Old 03-13-2010, 12:34 AM   #20
Gtseviper
I hammered them into the head.....
I finally got my engine aligned in the bay...
94 tranny, g22, f22 mounts all around including 90-93 manual bracket...I just tapped the new required holes for the 90-93 tranny mount..and everything works great
tsx retrofit
f22b dohc boosted
custom gauges pods
