Okay so as of recent i installed 2 '12 inch subs powered by a 2 channel amp. At first it worked fine but then after a while everytime i hit a pothole or a bump on the road the door speakers would go out so i assumed they were grounding out so i taped off all the bare metal around the 6x9's in the back but the problem continues and now everytime i turn the deck up past say 18 eventually the door speakers will stop playing. Im guessing either the amp is pulling too much power and isnt leaving much for the door speakers OR i just need stronger door speakers. Any ideas, comments, or concerns are greatly appreciated.
Door speakers go out when bass hits??
Originally posted by Junior Smurff View PostOkay so as of recent i installed 2 '12 inch subs powered by a 2 channel amp. At first it worked fine but then after a while everytime i hit a pothole or a bump on the road the door speakers would go out so i assumed they were grounding out so i taped off all the bare metal around the 6x9's in the back but the problem continues and now everytime i turn the deck up past say 18 eventually the door speakers will stop playing. Im guessing either the amp is pulling too much power and isnt leaving much for the door speakers OR i just need stronger door speakers. Any ideas, comments, or concerns are greatly appreciated.
Check your door speaker wiring for loose connections along their entire length. Loss of sound due to physical jarring leads me to suspect a loose connection somewhere leading to intermittent loss of signal.~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
Project Deerslayer
UPDATE: DEER - 2, CB7 - 0
'93 EX 5-speed coupe
Short ram intake
Tenrai Himoto catback
Smashed front end
Random bits of deer blood & hair
