hey i was woundering if are cars has any type of advance timeing we car do to are cars
advance timeing
not unless you have extensive engine mods and a adjustable timing gear.
what are you running currently?
Official CIVICKILLER's members ride thread! http://www.cb7tuner.com/vbb/showthread.php?t=112829
rock her with the shocker!
I think he might be talking about ignition timing... Just twist the distributor.
It does nothing but shift the powerband around. I've been told no damage can be done, but Honda says that it's not safe to set the timing more than 2 degrees off of the stock setting (which is 15 degrees).
There's no point, really... no point in ignition OR cam timing adjustments, at least to a near-stock car.
hey civickiller my cars is just basic I/H/E and p12 thats all
deevergote thanks iam talkin about advance ignition timeing, so it wont do anything to my car if i advance the ignition timeing,
my friend has a sentra S-ER and i was able to hang with his car but then he advanced his timeing and now he justs pulls me everytime
86 supra NA (sold)
91 Supra turbo (drifter)
99 prelude SH (only when i wanna hit V-attack)
91 accord (turbo soon dead) "crashed"
97 civic hatch GSR-T (my babys mama ride) (stolen)
All it does is shift the powerband. Advancing it will gain top end, lose bottom end. Retarding it will do the opposite. You SHOULDN'T do any damage even at the extremes, but Honda recommends staying at 15... no lower than 13, and no higher than 17. It's not smart to adjust your timing without a timing light (cheap... $40 or so at most autoparts stores).
If it's a B13 or B14 SE-R that your friend has, it has the 140hp SR20DE engine... and both cars weigh a good deal less than a CB7 (which has 140hp maximum). If it's a B15 SE-R, he's got 165hp, again in a lighter car (though the weight difference between the CB7 and the B15 is slight)
Originally posted by mn_cb7_boi View Posthey civickiller my cars is just basic I/H/E and p12 thats all
yea he has a b13 sr20de wow with such a small advancement can to that much to a ser nice lol to bad it dosent work for are cars, i wounder if i advance my timeing and pump higher octane will it improve it by a few ponies
86 supra NA (sold)
Originally posted by mn_cb7_boi View Postyea he has a b13 sr20de wow with such a small advancement can to that much to a ser nice lol to bad it dosent work for are cars, i wounder if i advance my timeing and pump higher octane will it improve it by a few ponies
then beat him sideways!
there's a red mark on the flywheel on my 92 DX accord, does that relate to the 15 degrees alignement of the distributor?? There are also three closely spaced white lines on the other side of the white timing mark.
Can someone explain what all those marks are? I've been curious about them for a while, and I though it had to do with an outer boundary on the timing (marking 15 degrees or whatever.)
Originally posted by h22sparkle View PostMy car has advancement on timing depending on what grade fuel i use. Along with another program map thats int he computer which gives it more torque and power.
You need to grow up kid, noone gives a shit about your car or what you have to say about it.
lol yea my supra and prelude will take that B13 hands down but i wanna see what i can do with the CB first since thats my underdog car lol
sideways lol i like that Flatline lol
86 supra NA (sold)
i have always played with my timing on my cb. when u retard the it it uses way less gas and is real slow out the hole and doesn't have much power just riding around but when you get it above 4 grand it comes to life. advance it and its has WAY more torque just puttin around town and your high rpm isn't all that bad. i kept mine all the way advanced. but noticed my A6 would pull a little harder wit it retarded but not having that low rpm power
