I'm noticing ecu names being tossed around. Most ppl are saying if you have vtec then you need a p28 and if you have a non-vtec then you need a p06. There are many more ecu's to choose from besides those two. P06 is just a generic assumption, they really mean to say any non-vtec ecu...p06 just happens to be common and easy to find as is the p28.
ANY, i say again, ANY chippable ecu can be converted to do anything another does. You can take a p05 for a sohc d15, chip it, convert it to vtec, add in the 02 components and it'll run a type r just fine (after tuning).
This is a list of COMMON, not all, ecu's.
common chippable Non-vtec ecu's to choose from
p05
p06
p08
p74
p75 - make sure you get the obd1 ecu because there is an obd2
pr4
Common chippable vtec ecu's
p28
p30
p73
PR3
p72
I did this off the top of my head so correct me if anything is wrong. Happy tuning
p05
p06
p08
p74
pr4
p28
p30
p73
PR3
p72
