Cant find the key that goes by the shifter so i can move my car into the garage,any way to get around the lock or to just move the shift linkage by hand?
How do i get my car into neutral without it running?..
You might have to take the center console out then to actually gain access to the shifter assembly. I think you can see that area where the shift lock is on, once the console is out. Your other option is to put the key in the on position use the brake and take the car out of park without the car running. You have to leave the key in the ignition until after the car is moved then turn the key off and remove.
Originally posted by Rilas View PostYou might have to take the center console out then to actually gain access to the shifter assembly. I think you can see that area where the shift lock is on, once the console is out. Your other option is to put the key in the on position use the brake and take the car out of park without the car running. You have to leave the key in the ignition until after the car is moved then turn the key off and remove.Follow me on IG to see my builds/pics
dmfb919
Figured it out...threw a fresh battery in it to roll the windows down so i could try to steer the car and figured I'd try the console key one more time..it worked lol all it needed was a battery,the broken piece inside doesnt seem to bother it either,so i think I'm in the clearFollow me on IG to see my builds/pics
dmfb919
Originally posted by chi View PostI didnt know that it needed power to release. I feel dumb now lol90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by fleetw00d View PostActually, it doesn't (just verified this on a shifter out of the car). You don't necessarily need a key either, just something long and narrow. After inserting something into the key slot, you do still need to depress the button on the shifter handle to get it out of PARK.
I believe the release via the ignition slot is electrical, no? Or is there some sort of release linkage?
I haven't driven my Accord enough to know, but I remember with a lot of GM vehicles once the car was parked and turned off, if you cranked on the wheel a bit you coud lock the column in place real tight, and unless you exerted some pressure on it while trying to turn the key, the ignition wouldn't unlock it (automatics only obviously).
Maybe something like this was going on?My '91 LX build. Bought September 2017. Sold June 2020.
http://www.cb7tuner.com/vbb/showthre...r /> t=209871
Originally posted by deevergote View PostThe key slot next to the shifter (his is jammed), or the ignition slot?
Originally posted by wtfisafleek View PostI haven't driven my Accord enough to know, but I remember with a lot of GM vehicles once the car was parked and turned off, if you cranked on the wheel a bit you coud lock the column in place real tight, and unless you exerted some pressure on it while trying to turn the key, the ignition wouldn't unlock it (automatics only obviously).
Maybe something like this was going on?Last edited by Fleetw00d; 11-23-2017, 12:32 PM.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
