I think i just blew my motor. Compression is probably still good cause it cranks and sounds normal besides having rod knock from hell. I'm gonna go play guitar hero and sulk for awhile before i try to start tearing things apart.
It was probably oil starvation. Hadn't been over-revving it but the valve stem seals went out again and i was having to replace 4 quarts of oil about every 3 weeks. I replaced it again yesterday after hearing a little knocking but it may have been too late. Car was acting really funny today spitting and sputtering and on the way home from work the loud knocking sound started, i shifted to a higher gear and right when i pressed in the clutch pedal the engine shut off, released the clutch and it came right back on. Oil light started flickering, car started bucking...and then the knocking sound got LOUD AS HELL. Could be the end of that crank.
