92 fenders???
    92 fenders???
    Cant find any aftermarket fenders... would maybe fenders off later generations bolt on with little to no modification??
    Definitely not. You can use 90-93 fenders interchangeably, but no other car's fenders will work without significant custom alteration.
      I figured... just wanted a second opinion. I'll just order new one fenders and modify them my self... of course not sure what air vents to but like the look specially with the mesh grill inserts I'll put in
        Okay okay sounds like the parts I was talking about. Read somewhere there were get to find. Started panicking lol. Thanks for the info. I'll check it out. Seems helpful as ima bout to put a couple gs into bringing this thing back to life and then some
          If it's vented fenders you're after, there are a few different styles on the market. At least there were... which means you should be able to find some if you look around. Cheaper brands may require some finesse to get them to fit as cleanly as the factory fenders, but it's easy enough if you have the patience for it.
