View Post
f22b dohc built head
need over sized pistons
so I figured out the block need oversized pistons the other day so I thinking about going
12:1 aris pistons and cheap eBay rods
does anyone have any input ? most rods are made in the same factory overseas so I don't see the need to spend $$ for name brand ones
https://www.ebay.com/itm/Arias-86mm-...ZYmdwQ&vxp=mtr<--- pistons
https://www.ebay.com/itm/New-Racing-...lXxQA1&vxp=mtr<---rodsNo marathon gets easier later. ...
Not sure about gsr bolts. I’ve never heard that before.
Honestly, neither stock nor cheap rods are a great idea, but i would probably feel more comfortable with stock rods and good bolts.
Honestly though, you’d be better off just getting quality forged rods if you want to rev high. The cost of the damage that would be done from a failed rod at high rpm will be much greater than the cost of just building it right the first time.
If you are getting pistons might as well get rods. hit up arias pistons they have 12:1 pistons also they can get you a deal on rods. Over all you are looking at atleast 1100$ for both befor machine work. Also arp makes rod bolts for the f22a/b. They are the ones you use for this motor. The bottom end is all f22a/b parts besides the pistons and lower timing cog. Everything else is all f22a/b.Last edited by 92smokeaccord; 05-09-2018, 12:28 AM.
