What automatic transmission fluid would you prefer
    My trans went out recently so I'm heading out to pull a part this week to get a trans what fluid do you guys usely run I was planning on flushing out the new trans before i started running it
    I recommend honda automatic transmission fluid
      +1 For Honda
        Honda z1 ATF, not the DW-1. Good luck finding it now.
          Exactly!
          Thats why i use Vavoline Dex/Merc 3 and buy an extra additive.
          EDIT: BTW i rebuild transmissions and transfer cases for a living.
            You could stock up on Z1, but I'm switching to max life starting my next drain/fill. BITOG seems to think it's ok, for the most part.
              ok so what should i use that i can get at autozone lol
                Z1 was discontinued last year. Its already hard/expensive to get.
                To the OP, if you can get your hands on Redline D4 or Amsoil high performance universl fluid. That is about the best anymore IMO. I see alot of cars doing well at the shop after using eather of the two. They never have came back to the shop for transmission work yet.
                Ive seen one guy with an 90 Accord auto we put Vavoline Dex/Merc 3 in with 205k on that trans since the rebuild i did 3 years ago.
                So if you cant get Redline D4 or Amsoil at your autozone, get Vavoline Dex/Merc 3.
                  I actually just bought MaxLife from AutoZone.
                    thanks guys now just gotta hit up pull apart and yank a trans
                      This isnt a bad choice. Again, ive been doing this for 4 years and went to school for it while i was working the first 2.
                      Stay away from "house" brand universal fluids. They say they will work in every vehicle ever made without a CVT pretty much. I have seen premature failures when using these.
                        Honda ATF. Trust me, lol.
                          this is true last time i did a flush i used kendall an added an aditive an thats probably why when i pulled my plug to drain my trans before i pulled it it had metal shavings all over it
                            Except Z1 is discontinued, and the new stuff isn't ideal for our needs.
                              @ Purple91ex That always sucks. What your looking for looks like this
                              The back of the bottle will say " Honda (1989-1995 models)
                              Im currently using it, a guy i know is using it. I use it every day in customers cars. You wont be sorry. This is what i recommend for people who dont want to shell out the money for Honda ATF that isnt exactly what it calls for anymore eather. Most of the people on here that say honda, honda, honda, havent ever tried anything else and have no idea what happens if you dont use Honda ATF. It works great. Just as good as $10/qt Honda ATF. The transmission shifts just as good and lasts just as long.
