ok i have a prelude which im doing a f22 block h23 head swap. i got the head gasket today its a felpro for f23 and f22 it fit right over the chambers but 2 of the coolant holes are blocked off on the gasket , i looked up the write up on it he dont say anyything about them . heres a pic i found my queston is in the red part and the head has holes for those...so wat do i do??
h23/f22 swap headgasket question ?
make sure u got the oil pressure sensor plug on there tight.. and that the plug isnt halfway loose.. causing a short in the signal..
secondly u did infact use a f23a/98+ accord headgasket right??? ur not suppost to have interference with coolant holes.. rather a corner of the gasket that doesnt line up with an oil drain..
anyhow.. just keep checking for leaks from the timing belt side upper right hand corner.. if u didnt silicion/jbweld/honda bond or variant u might spring an oil leak... it will seep up in most cases when its done wrong..
Praise The Lowered...
well now the oil light comes on lil by lil at start and after it warmes up it just stays on....my oil looks like its gray at the very tip of dip stick and near the dots its looks like its clear or something , idk if its water or wat dont look like oil , i have no leaks that i can see , i did swithc the oil pna with h23 one and put a new gasket , tomarro will check and see wtf happend , aslo i only honda bonded that one spot u said thats it ...
yes sir.........did u get the head and block resurfaced before putting it back together? Did you use new headstuds or originals? The original OEM head studs are stretch type which means after they are torqued down the first time, they stretch. ARP headstuds dont do that which is why they are reuseable. If the head and block werent resurfaced, then there is a likeliness of an unproperly mated surface which is why you are mixing coolant and oil.
IMO i would rebuild the h23 since the h23 is a hell of a base to start with. Whether its boost or its All motor or just to have to drive from point a to b. I wanna do a h23 build one day........Once the f22 i have blows up along with the f22/h23 motor i have sitting and waiting lol. Same build you have there
