1998 Galant-Please help Forum.
    This is for my neighbor. Please help. Driver side window doesn't want 2 go down.
    I know to check fuse.. if its not that can it be a switch or motor.
    Should I start with checkin for fuse first? Its her first car, all she wants is the window to go down. Its electric.
    Start with fuses, then check for power at the switch. If there's power going into the switch but not out then It's a bad switch. If the switch checks out then my guess would be a bad window motor. If It's the motor it should of been showing signs like slow speed or maybe binding up.
      Fuse controls the window circuit not just one window motor. Check for power at the window motor plug when you work the switch. Also make sure everything's plugged in when your testing it. Plug will have 2 wires, both will be grounds until the switch is activated. Up will be power on one wire, down will be power at the other wire. They alternate. Check motor first if you haven't got it yet.
        Thanks
