Hello everyone I recently purchased a set of 1996 Prelude Si blades and wanted the opinions of those who have painted their rims. For example the steps you took and what kind of products you use (Brand names) and how satisfied where you with the end results?
Paint Prelude Blades?
I use the following:
Super Clean (Diluted)
Eagle Mag Cleaner
Nail Scrub Brush (From Autozone)
Depending on it they have a clearcoat or paint already, use Jasco paint stripper. Its usually available at Home Depot or Lowes.
If there are any knicks, start with a mid grade sand paper and work up to finer. Usually 600-800 depending on how bad, then work up to 1000-1200.
Plastidip is a pretty neat substance for "painting" wheels especially, since you can easily get rid of the coat or replace it if it gets too worn.
Other than that, I would probably get a powdercoating instead of a spray can job. You can disregard this bit since I doubt you'll change your mind.
Originally posted by HardInThePaint View PostI agree. But if you can't remove the tire then just use a deck of cards.
That's what I used cards... and sir u have sivtec blades. Regular si wheels r 7 spokes. Coming from the h23 bb2 I guess.**Blk Housed Slut Crew Member #1**
Originally posted by oni_cb7 View PostI'd recommend regular 3x5 note cards over a deck of playing cards. Most likely cheaper and easier to work with than playing cards.
Originally posted by F20A CB7 View PostBingo was his name0!
That's what I used cards... and sir u have sivtec blades. Regular si wheels r 7 spokes. Coming from the h23 bb2 I guess.The CB7 Collector.Team Kindred Impulse Member #392 LX Coupe F22A12013 Toyota Corolla S92 EX Sedan F22A1Originally posted by deevergoteDo you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)
So your saying they designed the wheel after a cooling idea for the brakes?**Blk Housed Slut Crew Member #1**
Here's a link to a very good write-up i followed when i painted my wheels.
http://honda-tech.com/showthread.php?t=1356908
Originally posted by AmznAzn View Postif you want to save some money, i cut up some cardboard from a cereal box and just used that to cover my tires
and if you do decide to use plasti dip make sure the can AND the wheel are relatively warm, if not the paint will come out with a texture.
you can get index cards from the doller store? alot easlier just make sure you mask of your valve stem. honestly before you start id have them balanced with the weights on the inside if you havent already. then go about prepping and sanding, prep is key to any paint job. not meaning to highjack but has anyone ever tried the copper rim paint on oem rims? im thinking about giving it a go i got a brand new set of cd5 rims coming.
