I believe it does have rear discs, but I'm not 100% sure about the prop valve...
Adhit, does the car come with ABS? As far as I can remember I don't think they do, but I could be wrong..
Ahh I remember back in the day when the '92 CB first came out..I couldn't stop playing with the PFM lol comes from the factory yo!
Anyways, after you do all the things you just listed above the car should feel different..and if not, then just keep advancing the timing and put higher octane gas
Ronald
It does not come with ABS too bad. LOL the PFM, I always do that whenever I park the car in the garage.
I am dissapointed with my Apexi N1 coilover. The lowest height setting for the coilover is the same height as my stock shocks and springs. Is it possible that dual springs make the height of the car higher?
Yea it probably does. Those dont lowero the crap out of your car unfortunately. At least the ride is stiffer I hope. You might be able to take out the helper springs and lower it more.
Yea, I hope so. The ride is stiff though. I am guessing by taking out the helper springs, I will gain a drop of approx 2.5cm max. Well it is better than nothing. My previous front passenger shock & springs was out of alignment. So that was the reason I install my Apexi. I will take picture of the ride with the Apexi.
Here is the picture of the installed Apexi N1 with dual springs at the lowest setting (front side).
Then I started taking off the helper spring.
Here are the picture after I took off the helper spring, FYI I have not install the rear side yet. It still has approx 1.25" left to the lowest setting and yet I could not bring out my car from the garage since it was stuck. So I had to raise it a little bit.
This was after I raised the setting a little bit, and the coilover has approx 1.5" left to the lowet setting.
I just installed the rear passenger side shock + coilover. And I was right about the length of the shock, my SM4 strut is longer approx 10cm than the apexi. As you can see from the pictures below. The diameter of the shock also different, the diameter of the apexi shock is approx 42mm or 46mm.
