Hey guys, I have a 90 cb that has a no start issue, I have no spark, no pump prime and cel stays lit even while the plug is jumped codes do not read nor does cel blink just stays solid.
What I have done so far was, checked and cleaned grounds, result car cranked harder. 2nd thing I did was hot wire the pump and got fuel to the rail, 3rd thing I did was jump the injectors as well as tested with a bolt meter also checked volts at fuel pump plug both areas get power.
After that I ended up buying a new main relay as well as checked to see if volts were going to main relay they were. Checked volts to Ecu again they were and used working Ecus as well so far same result no codes when jumped, no fuel pump prime no spark. Also bought a distributor new and same result no spark. Has anyone encountered this issue and if so what was done.
Also I checked and replaced all the fuses with new fuses. And fuse boxes again coming from working cars when swap to the donor car fuse boxes and fuses worked.
Please I need to get this car going so I can fix the problems in my other car bad bushings and engine problems need to be addressed. I'd go to a shop but I don't have the money to pay for everything to get get done especially if I can do it myself and spend 500 on parts
