H22A specs clarification
    Would some one clear this for me:
    1994 H22A VTEC (black top) with original Automatic Tranny and original P13 ECU i was told this makes only 180HP because its automatic.. is this true? if so thats $1500 for only 40 Hp more i would of just turbo my F22A6.
    If any one can clear this up for me i know H22A they range around 190Hp-220hp depending on model but 180HP? is this correct or a my a victim of a vtec hater . . .
    I am positive is wrong input by a hater so i want to hear the opinion of my fellow CB7 owners.
    Are you asking about a USDM or jdm h22a?
      JDM H22A makes 200 HP auto or manual.
      Tippey, I would assume JDM H22 if he is talking about a 1994 with an automatic
      1992 Accord Wagon (RETIRED)
        good question and yes a legit JDM , with its original ecu tranny and all , and its new intake header 2" exhaust i was about to say 180hp?! what.. since i dint see any auto dyno ,specs on Google or forum etc it had me thinking .
          a lot of engine importers don't know jack shit about the engines they import
          ....and on the 7th day, deevergote rested and called his mom.
            Actually, JDM H22a makes 190PS and 200PS
            Accord applications: 190PS
            Preludes: 200PS
            Click sig to view MR thread
            Links to other rides:
            Honda Accord Euro-R
            Honda Odyssey Absolute
            Honda City I-DSi
            Honda Stream
              Preludes: 200PS
              http://www.mr2ownersclub.com/converter.htm
              if you want an easy way to convert metric hp (ps) to hp, don't think ps caught on in most places, about like our standard units system
                Are you sure its not the JDM F20B? It looks similar to an H22, and to my knowlede it had less HP for the auto version than it did for the manual.
                I dont believe the H22 came with different powers based on the tranny it was sold with.
                Sold to: dbsharp, daheavyking X3
                Bought from:'93CB7Ex, xkjnboix, duffmanivxx, remix405, CB7tuner official shop
                  no its not the F20b , the bar on the engine says H22A , and if am not wrong the F20B is a blue top right? , mine is black. but it makes sense to me that auto and stick had same power rating i can understand 0-10hp lost but 20hp is to much .
                    Everyone likes to rate their H22's based on the assembly line crank Hp specs from 1994! Not hard to see why so many people get upset when their 17 year old H22A VTEC only puts down 170 on a dyno....
                    Most of the numbers that people are posting are from wiki's and other online forums. Most of them are Honda's crank Hp specs, not actual power to the ground. The stock H22A black top is rated for 200 crank Hp. That could work out to be anywhere between 160-180whp on a 17 year old engine. Drop in the type S and it could bump it up to 175-200whp.
                    Your F22A6 is probably only putting down 110-120whp! $1500 for 180whp is a bit bigger jump than you thought. Putting 60 more ponies to the ground isn't cheap. However, your initial thoughts of boosting your A6 are correct. It would be cheaper, initially, to boost your F22A6 to get more wheel Hp than a stock 17 year old H22A.
                    MR Thread
                    GhostAccord 2.4L Blog
                    by Chappy, on Flickr
                      Here is a stock internal H22A with 80k with some bolt on mods putting 190 to the ground. With a tuned ECU, not a stock P13.
                      http://www.preludepower.com/forums/s...d.php?t=211919
                      This is phatdoughnut's CB7, He is a member on here as well.
                      http://www.cb7tuner.com/vbb/showthre...ghlight=Accord
                      MR Thread
                        yea i get what you mean my F22A6 had 300,000 miles on it and i can feel the power faded away but the H22A has under 30K that's why i got it 0_0 but well see i want to boost the h22 i know its not easy but its ether that or sale it and buy an evo or impreza and work with that.
