Some Anomalies During Prep For Engine Removal
    Hi again. I was underneath my engine while trying to remove the exhaust bolts, when I noticed this cable running from my transmission to what must be the shift stick:
    Now from the obvious looks of it, I must remove this cable if I want to remove the transmission with the engine. Problem is, the honda manual doesn't tell you how to remove it and it doesn't even list it as one of the parts to remove.
    How am I supposed to remove this cable?
    I tried to pry the thing out but it didn't move much, leading me to stop and reconsider what I was doing.
    “Speed has never killed anyone. Suddenly becoming stationary, that's what gets you.”
    ― Jeremy Clarkson
    If it is your shifter cables, they can be disconnected at the transmission. If it's not your shifter cables, then I'm at a loss.
    I just pulled my engine out yesterday with the transmission attached and the only cables that I had to remove were the shifter cables, and I disconnected them at the transmission end...
      OP has an automatic. You'll need to remove that tin cover and then release the cable inside. It's pretty self-explanatory.
        to remove it you need to remove the three 12mm bolts then take the 10 mm bolt off and slide it towards the oil pan theres also a weird washer with a tab you need to bend it back before unbolting the 10mm
          Thank you very much. This is my first time doing anything this serious with the car and I am very exited, however there have been moments where I lose confidence in myself, that's when I look into the official shop manual - which is the Bible of the car (as ETCG said). Then I am not so fearful that I will mess it up.
          ― Jeremy Clarkson
            dont worry i learned by breaking things once youve done it twice you know what not to do
