i was running a h22a4 and blown it up. then got a h22ajdm motor and through it in and wouldnt start or spark. found an extra sensor from the crank area of the h22a4. thinking that its the problem, i wanted to use my friends h23dizzy but there are two plugs on it. one with 2 wires and the other has 6 wires and the h22a4 dizzy has one with 2 wires and the other has 4 wires?? how would i modify my harness to work...wat can we do??
h22a4 dizzy vs h22a jdm dizzy
We had two bags of grass, seventy-five pellets of mescaline, five sheets of high-powered blotter acid, a saltshaker half-full of cocaine, and a whole galaxy of multi-colored uppers, downers, screamers, laughers... Also, a quart of tequila, a quart of rum, a case of beer, a pint of raw ether, and two dozen amyls.Tags: None
did i mention this is in my 98 civic... with the civic harness...
Originally posted by ibr_adam09 View Postyou can use either dizzy h22 a4 or the A
i would not modify wires to make it work , it probly wont and sumtin might go wrong
not only that...the a4 dont have a sensor in the dizzy like the one off my h23 dizzy..
