Rod Knock / Timing belt tensioner??? Knocks at around 2000 RPMS (HELP PLEASE!)
    does that help at all?
      so i discovered when i parked my car this morning when it was real good and hot that the "rattle" is there when in neutral while keeping the throttle / rpms consistant at like 1800 rpms even (so not just under a light load) - its quieter of course... but its like a changing rattle that does sound like something that is rotating -- still a deeper sound -- does that make it point to anything in particular folks????
      PLEASE HELP --- i might drop it off next week for a t-belt and tensioner and would rather not waste the money! - which is why im sticking to the advance auto or whatever gift card if you can solve it cause it;ll save me money!
        ....... Bump
          are you positive the noise is coming from the engine? why not invest in a stethiscope and listen a little more closely. Theres a pretty long thread about a similar noise on HT where the guy found that he had crushed a bearing inside his transmission that was causing a knocking sound when driving. does your car make the noise when not in motion? Id prop the thing up on jackstands and get it to make the noise when stationary that way you can crawl around it and pinpoint the location of the noise.
          member ride thread
          DIVULGE MOTORSPORTS
          John 10:18 "No one takes it from me, but I lay it down of my own accord. I have authority to lay it down and authority to take it up again. "
            definitely engine - or very near like timing belt --- not drivebelts-- and does it when not in motion in neutral also... like a friggin loose cam or something... i dont friggin know - my mechanic got out a long screwdriver at least and said its not the bottom end at least he believes... his theory is the tb tensioner... guess ill get it done and check back unless you might think im wasting money...
              saturday morning bump
                Sunday morning bump...
                  So I think im gonna pick up a boneyard engine with 52k miles on it for $300 (these motors are a dime a dozen in junkyards cause theres so many of them right now and usually as we all know, honda engines are bulletproof!)
                  so ill just have my mechanic toss a new belt on that motor so i dont have to worry about it and have him put a new clutch in while the motor's out so I won't have to worry about that either -- all in all the labor shouldnt be much more than like $600 - which is what you'd expect to pay a stealership for labor on just a friggin timing belt and valve adjustment! and thats not even considering the clutch change which - who knows, could end up going in another 10 or 20k miles anyway....
                  just let me know this is a good decision folks... No more "unnessary bumps" -- i'll just let you all know how it goes.
                    and this sounds a lot like my car only i think a little bit louder.. i shoudl get an mp3 at least or something for you folks to hear... just not sure how to do it...
                    http://www.youtube.com/watch?v=LjtqaIRYxms
                    and you;ll see this guy said he ended up throwing a rod...
                    Actually i just went back to youtube and searched and this noise is pretty similary only quieter this time... haha but its the exact same like tone and speed and everything... what you all think?
                    http://www.youtube.com/watch?v=U5W46ynZf7w
                    Dont know what happened with this guys motor...
                      So I think its a "wrist pin" that knocks when the engine heats up and under light load only... How bad is a wrist pin? Its my latest theory and I'm pretty confident in it now...
                        wrist pins are generally a more random knocking sound. That second video i cant hear anything related to what your describing.
                        member ride thread
                        DIVULGE MOTORSPORTS
                          The female's jeep had this problem. Only at a certain rpm it would tick, but this's with her oil pressure light on, but we thought it was just a sensor. About a week down the road, it started knockin' real bad. Oil pump was on it's last limb.
                          98' Mustang 3V Swap
                          11' VW CC R36
                            Mine kinda make a faint sound, it runs fine though.
                            http://s229.photobucket.com/albums/e...t=SN850747.flv
                            wat?
                              hmmm yeah -- -your sound is def different.... I shoulda taken a better video.. The audio doesnt do it justice and the motor wasnt hot enough when i did it too --(it makes the noise the most when its really good and warmed up) -- can't be detonation though just for the record... When i pull the #3 plug wire it gets a lil quieter...
                                OMG! I have this problem!
                                I am driving a 2002 Nissan Maxima SE with a v6... and honestly... I am having the same problem as stanlee!
                                It does not "rattle" when idling in position but when I am driving and the rpms switch between 1700-2200 RPMS (I think about the time I shift gears) ... it rattles... and if I am staying roughly between those RPMS when driving, it makes that noise. I dont know what it is and I have taken it to 2 mechanics now and they cant find anything wrong.
                                I just dont know what it is... It only happens when I am in motion and between 1700-2200 RPMS.
