Old 02-28-2019, 05:29 PM   #1
zedjr10
zedjr10 may have said something they shouldn't have...
Do 6.5 or 6.25 speakers fit in those DX/LX pods?
I got a 92 ex coupe, which has those speaker thingies. SO i went to JY and got 2 speaker pods out of a 90 DX/LX. I keep reading that 6.5 speakers are suppose to fit in there. I measure the distance across and it is 6 1/4's. What is going on here.
Old 02-28-2019, 06:02 PM   #2
sonikaccord
6.5" Speakers have an overall diameter of around 6.5".
The mounting diameter, the part that fits in the hole, is less than 6.5". Usually 6.3" or less.
Edit: around 5.75" mounting diameter
Old 02-28-2019, 07:05 PM   #3
zedjr10
So i got to find a set of 6.5 speakers that fit my 6.25 mounting diameter? So no ordering speakers from amazon. I must go to a store.
Old 02-28-2019, 09:47 PM   #4
Rilas
Zed I think your issue is that you got the wrong speaker pods. DX/LX have round smaller rear speakers than the EX/SE which have the oval larger speakers. Go back to the junkyard find an EX/SE grab those pods and you should be good to go.
Old 02-28-2019, 09:52 PM   #5
zedjr10
I am talking about the fronts. I should of clarified that is was the fronts am talking about.
Old 03-01-2019, 12:33 PM   #6
sonikaccord
You can order speakers from Amazon. Make sure you verify the specs and dimensions first.
Honestly mounting *depth* should be your primary concern as you may have to cut the back of the speaker pod out to fit your new speakers.
Old 03-16-2019, 02:03 AM   #7
zedjr10
I got some dx/lx pods and 6.5 speakers fit fine if you get 2 inch mounting depth or below.I got the infinity reference shallow mount speakers for front which are 1 and 13/16th inch depth. The accord ex pods only fit like 4inch with that speaker box it comes with. Which i think is stupid. Hope this helps someone.
