Getting higher rpm?
    Getting higher rpm?
    I have a f22a1 and boosted 12lbs and I'm try new ecu's I have a h22 ecu a ls ecu and a gsr ecu they all run the car but rpm does not change still red lines at 6500 ? WTF ! Why the gsr ecu alone show hit like 8000 please help . Just trying to change redline don't care about check engine light
    Why do you want a higher rev limit? Are you making power up there? Dyno graph?
      First off you need an tune to dial in your motor. An ecu change will not do anything to your redline unless you have dyno'd your. Does any of your ecus have a chip in installed in them I only ask b'cuz you did not mention it.
      If you don't have a chipped ecu I suggest you get one chipped and run hondata s200 or s300
      Oh and the reason why you can rev to an higher rpm is b'cuz you have cel light on and the base map for the ecu's are for stock untuned cars.
      NEW CB
      old Darkcloud : 1990 Accord EX MRT
      new
      DARKCLOUD : 90 ACCORD EX MRT
