F20b DOHC swap in a cb parts list
    Originally posted by axle View Post
    This is the link.
    http://www.hmotorsonline.com/shop/wh...#Miscellaneous
    It is under the BB4 92-96 Preludes section.
    F20B OEM Honda Head Gasket - Brand New OEM Head Gasket. $99.00
    14400-PCB-004 F20B OEM Honda Timing Belt - Brand New F20B OEM Timing Belt For a F20B engine only. $125.00
    F20B/Euro R Single Belt Crank Pulley - Brand New OEM Honda Pulley, Will Fit All F,H Series Motors $155.00
    Finally, one last thing I forgot to ask. I noticed that all H Series and F series Transmissions work on both engine. I figure that this would be true with the swap also.
    im assuming you cant walk into a dealer and order those parts right?
    COUPE K24
      no because this engine wasn't made for us cars as soon as you say I need part number PCB its like your speaking foreign language lol
      STANCE|WORKS
        True, I have a buddy that works up at Manchester Motorsports in Manchester, Ct. that was able to get me a lot of non-US Honda OEM parts. You have to wait for them to get to the dealership, but It has always worked for me. He got me a set of PCT Type-R pistons for a CTR that I put in a B16 back in the day with relative ease.
        My MRT
        White Devil Owned by Axle
        Go Fast or Suck
          Tcu to use with auto swap
          After some research and trial and error I have found the best ecu/tcu combination to use in my auto F22b swap is a P78 tcu from the 94-95 Integra LS. The tcu's maximum WOT shift point is 7k 200 rpm short of the P39's 7200 rpm fuel cutoff. This has great part throttle shifting and maximum upper rpm shift points. In D4 the car pulls to 7K and 40mph in first gear and 2nd is a killer. The only down fall is the D4 light on the dash blink similar to using the 94-95 accord tcu, but drivabilty is not a issue at all.
            Does any one know how to tell the difference between the 200hp and 180hp version?
            Thanks
              throttle body size
              PSN ID's:Tidashoni
              1992 Accord EX Coupe
              My FS Thread
              Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
                Thanks
                Also when u get the engine it will have eithet the auto fly wheel or manual one. Get it from h motors tho. Tiger is kinda idk. I didn't like them haha. Mine came with a red top also. You could try this ask for the one with a manual fly wheel cause u have the manual transmissiin and meed that one to match and to the one with the bigger tb.
                Accord SE
                93se
                Members Ride
                  does the ecu you get from hmotors work with out cars? its a PCB.
                  http://www.hmotorsonline.com/shop/sc...age&item=30013
                  Originally posted by scudweiser
                  i farted while i was getting head once, i was drunk.
                    anyone?
                      no the pcb computer is for an obd2 car and wire harness from a different car. you will need either a p28 or a p06.
                      Accord SE
                      93se
                      Members Ride
                        So what I'm getting from this for a 'bought not built' guy (because I'm a better driver than I am a wrench) and (all my wrench heads are back in Florida I'm alone here in Jersey) is this swap is a little complicated to hand in to a shop who aren't Honda heads not specialists? I really want the F20b over the H22 because I'm a fan of rarity, but this seems like a bit of a headache? What do you guys think?
                        FYI my goal is a DOHC as a daily just to have a little more umph behind the wheel along with LSD.
                        Thoughts? Suggestions?
                        Ol' Skool FTW!
                          It probably would be better to find a local member to do this for that has experience then it would to take it to a shop with out the knowledge of doing this swap.
                          I'm not saying the f20b is as common as a h22 swap but it's hardly rare.
                          CB7TUNER.com
                          Educating each other one car at a time.
                            So what, make a thread titled "who can do an f20b swap for me in Jersey?"
                            Ol' Skool FTW!
                              yeah, just make sure you put it in the regional section of the forum
                              CB7TUNER.com
                                I don't know if anyone has done it before but the manual F20B ecu can be used in the cb7. There is no immobilizer in this ecu and i was able to get mine running with no CEL.
                                I plan to make a quick build thread showing the swap and sharing the wiring info once I get the last issue solved.
