1990's head/dash lights
    i have a '90 accord Ex and my headlights & tail lights are working but they will not switch from high/low... My dash & praking lights are not working at all.
    This is what i have done..
    Replaced the switch on the column
    Replaced the dimmer switch.
    Any idea what else i can check out?
    Check all of your fuses.
      What VERY few i could find i checked.
      under the hood
      Small light, interior light, dimmer relay, lighting relay
      I did't see any lighting fuse in the driver side fuse box..back up light/ turn signals work
        my dim lights are coming on when i turn the switch to parking lights.. no high beams at all... but the blue light will come on as if the lights are working
          Your headlights come on when the switch is in the park light position? Is the car a U.S. or Canadian?
            Yea i have low beam lights and tail lights (no matter what it is turned on) its a US car
              Ok, so could you please explain the sequence of events that led to the lights not working properly. I am assuming of course that they were working properly to begin with and no one else has monkeyed with things.
                Your front parklights are controlled by fuse #23 in the underhood fuse box and there are 2 relays there as well. One turns the headlights on and the dimmer relay switches high and low. if the blue indicator light is on in the dash these should be functioning correctly. So the problem is with the lights themselves. Check the grounds headlights are on the right side of the engine compartment and the park lights are on the left front corner. they are all black and going to the same screw on each side.
                  even after the dash lights stopped working with the headlight switch when i hit the remote lock/unlock button (viper alarm) they would flash but that has also now stopped
                    You need to give us more information. Starting from the beginning and what steps you have taken since. go to the stickies at the top and download the wiring diagram. It will show you where the fuses are and the relays. Do you have a test light?
