Today I was doing some maintenance on my 1993 Honda Accord 10th Anniversary Edition. I did a new valve cover gasket, spark plug seals, spark plugs, spark plug wires, valve adjustment, oil change, oil filter, and wanted to do a transmission drain and refill. I got everything done, but when I did the transmission drain plug, my ratchet extension broke off inside of the hole. Has this happened to anyone before? If so how did you fix it? I also want to know if anyone has ever used magnetic drain plugs for their engine oil and transmission. They say what it does is it makes tiny metal particles from normal use of the engine to attract and stick to the drain plug.
Ratchet Extension In Transmission Drain Plug
Go to autozone or advanced auto or whatever you have there and get the magnetic pole tool they have. It's like a automatic antenna, you just extend it and reach down in there and it should grab onto it and pull it out. It's only a few bucks if that. Worth a shot 8)
Looks like this.
http://item.mobileweb.ebay.com/viewi...d=370788520615Last edited by Dy2*STR33T-KING; 08-24-2013, 04:04 AM.
