So long story short, i had to get new horns for the car because the old ones has the connectors broke off the backs of them. Installed the new horns and they worked great.
Only thing that changed in between when they worked and stopped working was we had the SRS cover over the lower steering column off to try and get my steering wheel aligned (Put a new subframe in before the horn). And since then the horn has stopped working.
Before I put the new horns in you could hear the relay clicking when you push on the steering wheel, but now I cant hear anything.
So could there be something near the steering column we could have bumped that would cause the horn to not work? I also checked the relay and its fine.
Any suggestions would be great!
